Connect to a FDO via Plugin
Message 1 of 8
I am developing a plugin in which the user logs on to a Oracle server.
When the login is accepted I would like to create and connect a FDO to the same database.
Is there a way to create a FDO connection via a VB.Net plugin?
/ Per
Replies (7)
Message 2 of 8
norman.yuan
When you say "plug-in", hopefully you mean DLL developed with AutoCAD .NET API. Yes, you can connect to FDO source, as long as the FDO provider is available in the computer. There are 2 ways to do that:
1. AutoCAD Map (since 2008/9) comes with "platform API" (or geospatial API) that deals with FDO (and more).
If you download AutoCAD Map ObjectARX SDK, you can find the API's documentation and sample code on how to connect AutoCAD with FDO data source and get FDO goemetries/data into AutoCAD Map.
You can also go to Autodesk's Infrastructure Modeling DevBlog and searcg for "FDO", which would bring you a few articles on this topic.
2. You can also bypass AutoCAD Map's platform API and directly use FDO API (AutoCAD installation get all FDO components installed).
In most cases, you'll go with 1.
Norman Yuan
Drive CAD With Code
Message 3 of 8
Alfred.NESWADBA
let me add some info's to Norman's suggestions:
You can download the ObjectARX kit for Map3D >>>there<<<
Within that you have samples that show's how to connect to source data (FDO) using API like the sample "Map Samples\Platform\BuildMap"
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 8
I found a solution.
This is what I did.
Dim connManager As OSGeo.FDO.IConnectionManager = OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager()
Dim conn As OSGeo.FDO.Connections.IConnection = connManager.CreateConnection("Autodesk.Oracle.3.9")
conn.ConnectionString = "Service=SRID;Username=USERNAME;Password=PASSWORD;Datastore=SCHEMA"
conn.Open()
conn.Close()
Hope this helps someone!
// Per
Message 5 of 8
Alfred.NESWADBA
thx for your feedback and for showing your code, great!
- alfred -
Alfred NESWADBA
Message 6 of 8
fieldguy
What reference is required for OSGeo.FDO.IConnectionManager?
Message 7 of 8
norman.yuan
It is in assembly OSGeo.FDO.dll, which you can find with AutoCAD Map/Civil's installation location:
C:\...[AutoCAD201x]\Map\bin
To directly use FDO, you usually add references to:
OSGeo.FDO.dll
OSGeo.FDO.Common.dll
OSGeo.FDO.Geometry.dll
Norman Yuan
Drive CAD With Code
Message 8 of 8
fieldguy
Perfect - thank you!
