AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
get properties of MgGeometry
1 REPLY 1
608 Views, 1 Reply
     While reader.ReadNext()
                Dim geometry as MgGeometry = agfReader.Read(reader.GetGeometry(myLayer.FeatureGeometryName))
               Dim propcol As MgPropertyCollection = new MgPropertyCollection()
                Select Case geometry.GeometryType
Case MgGeometryType.MultiPolygon i = 0 tempString = Nothing collOfCoord.Clear() Dim multiPolygon As MgMultiPolygon = TryCast(geometry, MgMultiPolygon) Dim coordIterator as MgCoordinateIterator = multiPolygon.GetCoordinates() While coordIterator.MoveNext() Dim multiPolyCoord As MgCoordinate = coordIterator.GetCurrent() CollOfCoord.Add(MultiPolyCoord) End While
I have code to recognize which type of geometry preseneted on map. For every geometry on this map exists ID, LAYER_ID and so on... I'd like to know is there any way to get these properties(ID, LAYER_ID...) for current geometry?Screenshot_1.png
1 REPLY 1
tamara
tamara
 here is an example of reading feature properties (sorry I write in C#, you can translate it to VB online):
//Get feature service
MgFeatureService featureService = AcMapServiceFactory.GetService(MgServiceType.FeatureService) as MgFeatureService;
//Get class definition for class name
MgClassDefinition clDef = featureService.GetClassDefinition(resource, schemaName, className); MgPropertyDefinitionCollection classPropeties = clDef.GetProperties();
MgFeatureReader reader = featureService.SelectFeatures(resource, className, query);
while(reader.ReadNext())
foreach (var property in classPropeties)
string propertyName = property.Name;
//for data properties
if(property.GetPropertyType() == MgFeaturePropertyType.DataProperty)
var propDef = property as MgDataPropertyDefinition;
var propType = propDef.GetDataType();
switch (propType)
case (MgPropertyType.Int16):
Int16 prop16 = reader.GetInt16(propertyName);
break;
case (MgPropertyType.String):
Int32 prop32 = reader.GetInt32(propertyName);
break;
//etc.
//for geometry property
else if (property.GetPropertyType() == MgFeaturePropertyType.GeometricProperty)
var geomProp = property as MgGeometricPropertyDefinition;
var geomType = geomProp.GeometryTypes;
switch (geomType)
case (MgGeometryType.Polygon):
//your code
break;
//etc.
Hope it hepls.
switch (propType)
break;
break;
//etc.
switch (geomType)
//your code
break;
//etc.
Hope it hepls.
