AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Failed to connect to WMS services - AutoCAD map 3D
3 REPLIES 3
vaidas
556 Views, 3 Replies
hi, where we can get autocad map 3d 2017 objectarx 2017?
3 REPLIES 3
scheel
in reply to: vaidas
your question is a little bit confusing.
You can connect to WMS services in Map 3D and Civil 3D using FDO-Provider for WMS inside the Map Workspace window.
But this is in the box and you need no more as the Map 3D.
When you want to produce own addins than it may be that you need the objectarx.
In that case you will find it inside the Autodesk Developer Network (ADN).
Here ist the link to that webside: Autodesk Developer Network
Thorsten
Thorsten Scheel
Contelos GmbH
vaidas
in reply to: scheel
yes it is bad question, cant find how to delete this post.
scheel
in reply to: vaidas
You can close it as a solution, because my answer give you the right link.
Thorsten Scheel
Contelos GmbH
Technology Administrators
