hi, where we can get autocad map 3d 2017 objectarx 2017?
Solved by scheel. Go to Solution.
your question is a little bit confusing.
You can connect to WMS services in Map 3D and Civil 3D using FDO-Provider for WMS inside the Map Workspace window.
But this is in the box and you need no more as the Map 3D.
When you want to produce own addins than it may be that you need the objectarx.
In that case you will find it inside the Autodesk Developer Network (ADN).
Here ist the link to that webside: Autodesk Developer Network
Thorsten
Thorsten
yes it is bad question, cant find how to delete this post.
You can close it as a solution, because my answer give you the right link.
