Hello
Windows 8, AutoCAD MAP 3D 2015, Visual Studio Community 2015
crash AutoCAD when I want to debug a C# code :
I can generate the DLL
I can netload the DLL in AutoCAD
The DLL is working (or not) in AutoCAD and thus I want to make a debugging
in debug I put the path of the EXE (acad.exe)
I wrote a file.scr to netload the DLL but AutoCAD always crashes with the message in Visual Studio :
Le programme '[8888] acad.exe: Managé (v4.0.30319)' s'est arrêté avec le code -529697949 (0xe06d7363) 'Microsoft C++ Exception'.
I made dozens of searches on the net without finding satisfactory answer.
excuse my (non native) english,
thank you
Solved by -didier-. Go to Solution.
Try searching the error code 529697949.
http://lezhang.net/2014/04/29/529697949-0xe06d7363-microsoft-c-exception-with-revit-2015-api/
Have you visited the .net forum yet? There are several "debug" posts >>here<<
Hello
I made dozens of searches on the net without finding satisfactory answer and this one is known.
The real solution was found by Gilles ( French like me)
It is the problem which exists only on the not English versions :
This Topic to see the solution
Now, all is OK,
