AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
debug C#
2 REPLIES 2
-didier-
1062 Views, 2 Replies
debug C#
Hello
Windows 8, AutoCAD MAP 3D 2015, Visual Studio Community 2015
crash AutoCAD when I want to debug a C# code :
I can generate the DLL
I can netload the DLL in AutoCAD
The DLL is working (or not) in AutoCAD and thus I want to make a debugging
in debug I put the path of the EXE (acad.exe)
I wrote a file.scr to netload the DLL but AutoCAD always crashes with the message in Visual Studio :
Le programme '[8888] acad.exe: Managé (v4.0.30319)' s'est arrêté avec le code -529697949 (0xe06d7363) 'Microsoft C++ Exception'.
I made dozens of searches on the net without finding satisfactory answer.
excuse my (non native) english,
thank you
Éternel débutant.. my site for learning : Programmer dans AutoCAD
Didier Aveline
2 REPLIES 2
fieldguy
in reply to: -didier-
Try searching the error code 529697949.
http://lezhang.net/2014/04/29/529697949-0xe06d7363-microsoft-c-exception-with-revit-2015-api/
Have you visited the .net forum yet?  There are several "debug" posts >>here<<
-didier-
in reply to: fieldguy
Hello
I made dozens of searches on the net without finding satisfactory answer and this one is known.
The real solution was found by Gilles ( French like me)
It is the problem which exists only on the not English versions :
This Topic to see the solution
Now, all is OK,
Thanks for your help.
Didier Aveline
Technology Administrators
AutoCAD Beta
