Creating an AutoCAD table using .NET
please visit this article,
I quote the code :
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace TableCreation
public class Commands
[CommandMethod("CRT")]
static public void CreateTable()
Document doc =
Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptPointResult pr =
ed.GetPoint("\nEnter table insertion point: ");
if (pr.Status == PromptStatus.OK)
Table tb = new Table();
tb.TableStyle = db.Tablestyle;
tb.NumRows = 5;
tb.NumColumns = 3;
tb.SetRowHeight(3);
tb.SetColumnWidth(15);
tb.Position = pr.Value;
// Create a 2-dimensional array
// of our table contents
string[,] str = new string[5, 3];
str[0, 0] = "Part No.";
str[0, 1] = "Name ";
str[0, 2] = "Material ";
str[1, 0] = "1876-1";
str[1, 1] = "Flange";
str[1, 2] = "Perspex";
str[2, 0] = "0985-4";
str[2, 1] = "Bolt";
str[2, 2] = "Steel";
str[3, 0] = "3476-K";
str[3, 1] = "Tile";
str[3, 2] = "Ceramic";
str[4, 0] = "8734-3";
str[4, 1] = "Kean";
str[4, 2] = "Mostly water";
// Use a nested loop to add and format each cell
for (int i = 0; i < 5; i++)
for (int j = 0; j < 3; j++)
tb.SetTextHeight(i, j, 1);
tb.SetTextString(i, j, str[i, j]);
tb.SetAlignment(i, j, CellAlignment.MiddleCenter);
tb.GenerateLayout();
Transaction tr =
doc.TransactionManager.StartTransaction();
using (tr)
BlockTable bt =
(BlockTable)tr.GetObject(
doc.Database.BlockTableId,
OpenMode.ForRead
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(
bt[BlockTableRecord.ModelSpace],
OpenMode.ForWrite
btr.AppendEntity(tb);
tr.AddNewlyCreatedDBObject(tb, true);
tr.Commit();
Well, your quoted code is to create AutoCAD Table entity, which is TOTALLY different from AutoCAD MAP's OD Table (ObjectData Table).
