AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
creates OD tables with C#.net
3 REPLIES 3
1816 Views, 3 Replies
I need to edit and attach the Object Data to Objects in my drawing with C# .NET, but I dont know who is the way.
thanks all
3 REPLIES 3
Assuming you are using AcadMap's .NET API (set reference to
ManagedMapAPI.dll in your C# DLL project):
Some sample code:
//Create map project
Document
dwg=Autodesk.AutoCad.ApplicationServices.Application.DocumentManager.MdiDocument;
ProjectModel mMapProj =
HostMapApplicationServices.Application.Projects.GetProject(dwg);
//Create ODTable
if (!mMapProj.ODTables.IsTableDefined(tableName))
mMapProj.ODTables.Add(tableName, fieldDefs, tableDescription, true);
Simply explorer Managed MAP API for more available classes'
properties/methods
"rucieza" wrote in message news:5803665@discussion.autodesk.com...
thanks all
ahmedsayed551991
Creating an AutoCAD table using .NET
please visit this article,
I quote the code :
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace TableCreation
  public class Commands
    [CommandMethod("CRT")]
    static public void CreateTable()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      PromptPointResult pr =
        ed.GetPoint("\nEnter table insertion point: ");
      if (pr.Status == PromptStatus.OK)
        Table tb = new Table();
        tb.TableStyle = db.Tablestyle;
        tb.NumRows = 5;
        tb.NumColumns = 3;
        tb.SetRowHeight(3);
        tb.SetColumnWidth(15);
        tb.Position = pr.Value;
        // Create a 2-dimensional array
        // of our table contents
        string[,] str = new string[5, 3];
        str[0, 0] = "Part No.";
        str[0, 1] = "Name ";
        str[0, 2] = "Material ";
        str[1, 0] = "1876-1";
        str[1, 1] = "Flange";
        str[1, 2] = "Perspex";
        str[2, 0] = "0985-4";
        str[2, 1] = "Bolt";
        str[2, 2] = "Steel";
        str[3, 0] = "3476-K";
        str[3, 1] = "Tile";
        str[3, 2] = "Ceramic";
        str[4, 0] = "8734-3";
        str[4, 1] = "Kean";
        str[4, 2] = "Mostly water";
        // Use a nested loop to add and format each cell
        for (int i = 0; i < 5; i++)
          for (int j = 0; j < 3; j++)
            tb.SetTextHeight(i, j, 1);
            tb.SetTextString(i, j, str[i, j]);
            tb.SetAlignment(i, j, CellAlignment.MiddleCenter);
        tb.GenerateLayout();
        Transaction tr =
          doc.TransactionManager.StartTransaction();
        using (tr)
          BlockTable bt =
            (BlockTable)tr.GetObject(
              doc.Database.BlockTableId,
              OpenMode.ForRead
          BlockTableRecord btr =
            (BlockTableRecord)tr.GetObject(
              bt[BlockTableRecord.ModelSpace],
              OpenMode.ForWrite
          btr.AppendEntity(tb);
          tr.AddNewlyCreatedDBObject(tb, true);
          tr.Commit();
Ahmed Sayed
norman.yuan
Well, your quoted code is to create AutoCAD Table entity, which is TOTALLY different from AutoCAD MAP's OD Table (ObjectData Table).
Norman Yuan
Drive CAD With Code
