AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
遍历文本内容
1 REPLY 1
295 Views, 1 Reply
遍历文本内容
BlockTable  bt=(BlockTable)tr.GetObject(db.BlockTableId,OpenMode.ForRead,false);
BlockTableRecord btr=(BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace]),OpenMode.ForRead,false);
foreach(objectId id in btr)
    Entity ent=tr.GetObject(id,OpenMode.ForRead,false) as Entity;
    string se=id.ObjectClass.DxfName;
    if(se.Equals("TEXT"))
现在是先遍历实体,然后再在实体中找出文本。我现在想做的是在遍历实体前就筛选出文本类型,然后遍历文本类型的实体,该怎么做?请给出代码。
然后帮我找一个CAD中实现他查找对话框的代码。(就是在CAD中输入Find后出现的对话框),有实现这类功能的代码吗?
谢谢!
1 REPLY 1
norman.yuan
Well, if you don want to loop through entire ModelSpace for certain type of entities, you can use Editor.SelectAll(SelectionSetFilter filter), something like:
var vals = TypedValue[]
    new TypedValue((int)DxfCode.Start, "TEXT"),
    new TypedValue((int)DxfCode.LayoutName, "MODEL")
var res=activeDocument.Editor.SelelctAll(new SelectionSetFilter(vals));
if (res.Status==PromptStatus.OK)
    using (var tran=.....)
        foreach (var id in res.Value.GetObjectIds())
            var textEntity=(DbText)tran.GetObject(id, OpenMode.ForRead);
           //comparing DbText's TextString with the text to be searched for here
        tran.Commit()
In reality, looping through entire ModelSpace may not be as bad/as slow in comparison to getting a filtered SelectionSet, as one thinks, depending on drawing. And sometimes, the fraction of second difference is ignorable
Norman Yuan
Drive CAD With Code
