AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
autolisp extract more than one set from a string
2 REPLIES 2
edsaqueteAG5Q7
811 Views, 2 Replies
edsaqueteAG5Q7
Here's a file to test,
need to do a ssget to select everything inside the layer "POLI" to do as below, my translator translates wrong in the topic.
I need to extract as the example below
Numbering example:
1 - TT-AC1 (extract the 1 after the AC )
2 - 101-AC16,PT2 (extract the 16 after the AC)
3 - 17-BC1,AC3,PT2 (extract 1 after BC and extract 3 after AC)
Numbering example:
2 REPLIES 2
hosneyalaa
in reply to: edsaqueteAG5Q7
hosneyalaa
Hi
do you found The solution
Hi
edsaqueteAG5Q7
in reply to: hosneyalaa
edsaqueteAG5Q7
yes, i found a solution.
