Text problem
Text problem
Text problem
When opening an ascii file using 2008 the line it reads is converted to junk.
Here is a snippet:
(setq fn (open "c:\\braintree\\a.txt" "r"))
(while (setq s (read-line fn)) ;read a.txt and create a list of the drawings
(if (= plan 1)…….rest of code
The file a.txt looks like:
H12
L12
H13
If I look at the variable s it looks like "ÿþH\0001\0002\000" instead of "H12".
Have you got any ideas?
When you save the txt file make sure you set encoding to ANSI and not
Unicode.
Murph
wrote in message news:5840583@discussion.autodesk.com...
junk.
Here is a snippet:
drawings
(if (= plan 1)...rest of code
H12
L12
H13
"H12".
Can you give me an example of setting the encoding?
Don't know how you are creating the txt file but if you open it in Notepad
when you saveas it gives you the option.
Murph
wrote in message news:5840898@discussion.autodesk.com...
