odtable.getodrecords.init error
mirwing76
mirwing76
Function HasAttachRecord(objValue As AcadEntity, tblName As String) As Boolean
Dim ODtbl As AutocadMAP.ODTable
Dim ODtbls As AutocadMAP.ODTables
Dim ODRcs As AutocadMAP.ODRecords
Dim intODtablesCount As Integer
Dim intItem As Integer
Dim boolVal As Boolean
intItem = 0
Set ODtbls = proj.ODTables
intODtablesCount = ODtbls.Count - 1
For intItem = 0 To intODtablesCount
If ODtbls.Item(intItem).Name = tblName Then
Set ODtbl = aMap.Projects(ThisDrawing).ODTables.Item(intItem)
Exit For
End If
Next
Set ODRcs = ODtbl.GetODRecords
boolVal = ODRcs.Init(objValue, False, False)   ' This line error!! error measge "Run-time error '5':  Invalid procedure call or argument
'odTable  attatch / cad object  / yes
HasAttachRecord = true
'odTable  attatch / cad object  / no
HasAttachRecord = false
End Function
Help Me Please!!
dohenry
Hi mirwing76
It has been a few years since I have done VBA.
I quickly compared your code to some I had previously can't see anything straight of, however I have pasted below a extract from my code which may point you in the right direction.
I seem to remember the following line of code is important and notice it is missing from your code. And the second line is slight different to yours.
Set amap = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
Set ODrcs = amap.Projects.Item(ThisDrawing).ODTables.Item(Object_Data_Table).GetODRecords
'I had multiple objects so I used a selectionset
For i = 0 To objss.Count - 1    'I based
boolVal = ODrcs.Init(objss.Item(i), False, False)
Hope this is a help.
Good Look.
