boolVal = ODRcs.Init(gEntity, True, False) Error!!
mirwing76
Message 1 of 10
mirwing76
argument Error!! Function Init(acadObj As LPDISPATCH, openMode As Boolean, skipNested As Boolean) As Boolean
Member of AutocadMAP.ODRecords Initialize ODRecords with a new AutoCAD object identifier.
what is "LPDISPATCH" ? object Type? acadEntity ?
problem openMode OR skipNested ?
Cadmap ver.2017 , vba 7.?
Replies (9)
Message 2 of 10
mirwing76
cad map 2017 64bit.
gEntity = getEntity
set obj = gEntity
ODRc.AttachTo (obj.ObjectID)
overflow !! error!!
debug.print obj.ObjectID
 1738998788544
Function AttachTo(acadId As Long) As Boolean
Returns the AutoCAD object id associated with the record.
Message 3 of 10
norman.yuan
I am not sure what exactly you want to do, but assume this is what you want to achieve:
1. Create a ODTable, either via code, or manually create one. So, the code works against a ODTable with known table name
2. For every entity in modelspace, you want to see if the entity has the OD record from that table already attached or not. If not, you want to attach the OD record from that table; if already attached, optinally, you may want to update the record's values.
Checking if an entity has a OD record with given table namke is where you need to call ODRecords.Init(), which retrieves all OD records attached to an entities (these records could be froom multiple ODTables).
Here is sample code that runs OK in my AutoCAD Map/Civil2017:
Option Explicit
Public Sub TestODTable()
    Dim proj As AutocadMAP.Project
    Dim table As AutocadMAP.ODTable
    Dim acMap As AutocadMAP.AcadMap
    Set acMap = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
    Set proj = acMap.Projects(0)
    ''MsgBox proj.ODTables.Count & " Table(s) found"
    Set table = GetTargetTable("MY_OD_TABLE", proj)
    If table Is Nothing Then
        MsgBox "Object Data Table ""MY_OD_TABLE"" does not exist!"
        Exit Sub
    Else
        MsgBox "Object Data Table ""MY_OD_TABLE"" found"
    '' attach od record to all entities in modelspace with default values
    Dim ent As AcadEntity
    For Each ent In ThisDrawing.ModelSpace
        AttachOdRecord ent, table
    Next
End Sub
Private Function GetTargetTable( _
    tblName As String, proj As AutocadMAP.Project) As AutocadMAP.ODTable
    Dim tbl As AutocadMAP.ODTable
    For Each tbl In proj.ODTables
        If UCase(tbl.Name) = UCase(tblName) Then
            Set GetTargetTable = tbl
            Exit Function
    Next
    Set GetTargetTable = Nothing
End Function
Private Sub AttachOdRecord(ent As AcadEntity, tbl As AutocadMAP.ODTable)
    Dim r As AutocadMAP.ODRecord
    If Not HasTableRecord(ent, tbl) Then
        Set r = tbl.CreateRecord()
        r.AttachTo CLng(ent.ObjectID)
End Sub
Private Function HasTableRecord(ent As AcadEntity, tbl As AutocadMAP.ODTable) As Boolean
    Dim found As Boolean
    Dim rs As AutocadMAP.ODRecords
    Set rs = tbl.GetODRecords()
    If rs.Init(ent, False, True) Then
        Do Until rs.IsDone
            Set r = rs.Record
            If UCase(r.tableName) = UCase(tbl.Name) Then
                found = True
                Exit Do
            rs.Next
        Loop
    HasTableRecord = found
End Function
As you can see the code first verify the given table exists; then loop through each entity in modelspace to check if a record from that table is attached or not. If not, attach a record from that table. Pay attention to the function HasTableRecord(): This is where you are struggling. I think.
HTH
Norman Yuan
Drive CAD With Code
Message 4 of 10
mirwing76
Thanks a lot for your help.
The code you created will work fine. In "autocad map 2004"
 It does not work with "autocadmap 2017 64bit".
"If rs.Init (ent, False, True) Then"
An error occurs here.
What did you load References from in vba?
In my case.
1. Visual Basic For Applications.
2. AutoCad 2017 Type Libray.
3. OLE Automation
4. Autodesk Map 3D 2005
I am having trouble upgrading from "map 2004" to "map 2017" because the existing code is not working properly.
Translated into "Google Translator".
Message 5 of 10
norman.yuan
I am confused. IN your original post, you mentioned it is AutoCAD Map 2017. Now you say AutoCAD Map 2004.
The code I showed runs OK with my AutoCAD Map 2017.
Do you want it to run in AutoCAD Map 2017, or AutoCAD Map 2004? Or do you want the code run in both?
Since AutoCAD Map 2005 is the last version of AutoCAD Map's COM API ( reference to AcMapVbApi.tlb"), thus, for all version of AutoCAD Map since then, use the same COM API type library (AutoCAD Map 2005) for Map programming. If you use AutoCAD Map 2004, you still set reference to AcMapVbApi.tlb, which is different version (earlier version) that comes with AutoCAD Map 2004.
You cannot load the same *.dvb file in both AutoCAD Map 2004 and AutoCAD Map 2017. You need different version/file of the *.dvb, against corresponding version of AutoCAD Map, even though the code itself could be the same.
Norman Yuan
Drive CAD With Code
Message 6 of 10
mirwing76
It should work correctly with "autocad map 2017 64bit".
You still get an error in the code you provided.
The "rs.init" part.
Should I reinstall "autocad map"? Or should I reinstall "AutoCAD_2017_VBA_module_Win_64bit_dlm"?
I am always thankful for your help.
Message 7 of 10
flowerpapa
Hello Norman,
could please tell us about which are reference file have to be linked with vba,
because i have linked below references but still i get err in Map3d2019 version
Message 8 of 10
norman.yuan
I do not have AutoCAD Map/Civil 2019 available, but this code work OK both in AutoCAD Map 2018/2020:
Public Sub MapTest()
    Dim mapApp As AutocadMAP.AcadMap
    Set mapApp = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
    MsgBox "Map app: " & mapApp.Projects.Count
End Sub
So, I do not see any reason why it does not work in AutoCAD Map 2019.
Norman Yuan
Drive CAD With Code
Message 9 of 10
flowerpapa
Actually I'm using civil3d2019 version
Message 10 of 10
norman.yuan
Well, I should have said that what I used to run the code were actually Civil2018/2020. So, again, I do not see why Civil2019 would make it differently.
Norman Yuan
Drive CAD With Code
