Dbconnect.Connect
Dbconnect.Connect
Dbconnect.Connect
Hi all,
I try to use the function Dbconnect.Connect but it doesn't work. Nothing
error appear but if I look the Map project area I don't see the new
connection to datasource. Why?
Regards
Matteo Conte
If you add a datasource via DBConnect (CAO) you will not see it within the
Map Project Workspace - rather, you will find it within the DBConnect
Workspace - Tools>DBConnect (and Map does not recognize this datasource).
But, if you add a link template via DBConnect it will show up in both
workspaces, but you cannot use it with Map until you manually attach the
datasource within the Map Project Workspace. The ActiveX API for Map
currently does not allow you to attach Datasources.
I hope that makes sense.
Good Luck,
Scott
"Matteo Conte" wrote in message
news:A2517A5355C138752F11699012B92DB1@in.WebX.maYIadrTaRb...
> Hi all,
Nothing
> Regards
> Matteo Conte
