Selection set using filter with VBA
Hi
I am trying on AcadMAP VBA for selection set with filter using 'SelectOnScteen' request. I tried to copy the syntax from the code. But it didn't work. It Says 'Invalid FilterType'. Required HELP On this Topic.
Thanx
Sudhir Ogale
It should work. Can you please paste your code that
gives error?
Murali
Hi
Thanx
Sudhir Ogale
HI MURALI THANX FOR REPLY,
HERE IS THE CODE.
Private Sub CommandButton13_Click()
Me.Hide
Dim FilterType As Integer
Dim FilterData As String
Dim sset As AcadSelectionSet
Dim ent As AcadEntity
Dim name As String
'Dim sset As AcadSelectionSet
FilterType = 8
FilterData = "Vill_bnd"
Set sset = ThisDrawing.SelectionSets.add("ss1")
sset.SelectOnScreen FilterType, FilterData
For Each ent In sset
name = ent.ObjectName
MsgBox name
Next
sset.Delete
MsgBox "completed"
Me.Show
End Sub
WAITING FOR UR SOLUTION
THANX
BYE
SUDHIR
Here is some working code to select arcs.
You'll notive the Dim commands are different from yours
Dim FilterType(0)    As
Integer
Dim FilterData(0)    As Variant
Dim ssArcs As
AcadSelectionSet
    FilterType(0) = 0: FilterData(0) =
"ARC"
    Set ssArcs =
ThisDrawing.SelectionSets.Add("SSET")
Me.Hide
    ssArcs.SelectOnScreen FilterType, FilterData
' this selects arcs
Regards
HI
HERE IS THE CODE.
Me.Hide
Dim FilterType As
Integer
Dim name As
String
FilterType = 8
FilterData =
"Vill_bnd"
sset.SelectOnScreen
MsgBox name
Next
sset.Delete
MsgBox "completed"
Me.Show
End Sub
THANX
BYE
SUDHIR
Thanks Laurie
The given code is working
thanks again.
sudhir
