Data table name is already defined
I am posting this here because I discovered this programmatically. If you have a dwg file with an object data table that is attached via XREF, you cannot define a table with the same name in the current dwg.
To test: Create a new dwg file with an object data table called "tableone" with 1 or 2 fields. Save and close it.
Create another new dwg file, attach the first dwg as an XREF, and you CANNOT create a table called "tableone".
You get a "Table creation failed" error in the "Define Object Data" dialog, and a "Data table name is already defined" error in "Autocad Map Messages".
I don't understand this at all. This occurs in Civil 3D 2016. If someone with a newer release could try this for me to see if anything has changed?
Is there any workaround?
