Data table name is already defined
fieldguy
Advisor Advisor
fieldguy
I am posting this here because I discovered this programmatically.  If you have a dwg file with an object data table that is attached via XREF, you cannot define a table with the same name in the current dwg.
To test: Create a new dwg file with an object data table called "tableone" with 1 or 2 fields.  Save and close it.
Create another new dwg file, attach the first dwg as an XREF, and you CANNOT create a table called "tableone".
You get a "Table creation failed" error in the "Define Object Data" dialog, and a "Data table name is already defined" error in "Autocad Map Messages".
I don't understand this at all.  This occurs in Civil 3D 2016.  If someone with a newer release could try this for me to see if anything has changed?
Is there any workaround?
norman.yuan
@fieldguy, I have verified with my AutoCAD Civil2015, 2018 and 2019, all behave the same as you described: if the Xrefed drawing has OD Table, one cannot create OD table with the same table name as used in Xrefed drawing. So, I'd consider it is "by design"Smiley Sad
Norman Yuan
Drive CAD With Code
fieldguy
Thanks @norman.yuan.  That's what I thought.
I think the only workaround is to create the table in the current dwg before the XREF is attached.  We are testing that now - seems ok so far.
