set layerdefinition to layer
02:13 AM
Greetings! I faced to issue I can't set cutstom LayerDefinition to a layer. I have a code:
Public Shared Sub AddLegendStyleOnLayer(ByVal legendpath As String, ByVal fileName As String) Using locked As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument() Dim xmlFile As XmlDocument = New XmlDocument() xmlFile.Load("C:\Users\dea\AppData\Roaming\MgLocal\Repositories\Library\Content\Layers\DEA~DEA_GEOM_SPATIAL~GEOM.LayerDefinition") Dim unicodeBytes As Byte() = Encoding.Unicode.GetBytes(xmlFile.OuterXml) Dim utf8Bytes As Byte() = Encoding.Convert(Encoding.Unicode, Encoding.UTF8, unicodeBytes) Dim layerByteSource As MgByteSource = New MgByteSource(utf8Bytes, utf8Bytes.Length) Dim currentMap As AcMapMap = AcMapMap.GetCurrentMap() Dim rIDlayer As New MgResourceIdentifier("Library://Layers/" & Path.GetFileNameWithoutExtension(legendpath) & ".LayerDefinition") Dim xmlDirectory As String = "C:\Users\dea\AppData\Roaming\MgLocal\Repositories\Library\Content\Data\" rs.SetResource(rIDlayer, layerBytesource.GetReader(), Nothing) Dim rIdFeatureSource As New MgResourceIdentifier("Library://Data/" & fileName & ".FeatureSource") Dim featureSourceByteSource As New MgByteSource(xmlDirectory & "" & fileName & ".FeatureSource") featureSourceByteSource.SetMimeType("text/xml") rs.SetResource(rIdFeatureSource, featureSourceByteSource.GetReader(), Nothing) Dim layer1 As AcMapLayer layer1 = GetLayerByName("FeatureClass1") layer1.SetLayerDefinition(rIDlayer, rs) Dim updatedLayerByteSource As MgByteSource = UpdateByteSource(legendpath) rs.SetResource(layer1.LayerDefinition, updatedLayerByteSource.GetReader(), Nothing) layer1.ForceRefresh() 'exception on this string MsgBox("Everything is fine!") End Sub
And when I connect to data source (i.e SDF data source) and get layer (FeatureClass1) from LayerCollection by using GetLayerByName I get an exception: Null reference. The GWS layer source is invalid.
Any suggestions?
