Autodesk Map 3D 2012 FDO Problems
11:59 PM
- Mute
- Permalink
- Report
I have a project using FDO version 3.3.0.0. This project need the FDO Path and i put it in Environment Variable, says c:/fdo/bin. This project working good.
Last week i install Autodesk Map 3D 2012, it complain about '
c:\program files\autodesk\autocad map 3d 2012\acmapworkspace.arx cannot find a
procedure that it needs.' I can't open task pane and any other command. Through some investigation, i found that Autodesk Map 2012 read FDO from the environment variable. If i remove the fdo path in my environment variable than it work. Is it possible to make the map read FDO from its own FDO only, and not from env variable?
Thank
