Autocad Map 3D 2010 64 bit multiple documents fatal error
We are using AutoCAD Map 3D 2010 64 bit on windows 7 64 bit system. when we are working with multiple documents that ie two different douments opened in two autocad sessions. we are getting fatal error. we have installed service pack 2 but this we are facing this error. please let uw know how to over come this issue.
Alfred.NESWADBA
What command do you start when you get this error?
Have you verified (using command _AUDIT) in each of the drawings that their geometry database is ok?
What are your system-specs .... and what does the taskmanager tell you about the memory occupied by ACAD.EXE?
At least I would not know a common bug just because of having multiple documents open.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
braudpat
Hello
If you are running in Single Document Interface (Mode) --> SDI = 1
Have you the same problems ?
Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
