AutoCAD LT Forum
Write block changes sizes
4 REPLIES 4
jen_payne
222 Views, 4 Replies
When I insert a block I have written it is a different size to what I created it as. What am I doing wrong?
4 REPLIES 4
hwalker
in reply to: jen_payne
Please post the block and the drawing you're trying to insert it into.
Without a drawing it is difficult to help, but it sounds like e.g. your block is created in millimetres and your drawing is created in inches. Which would make your block 25.4 times bigger
Howard Walker
Left Handed and Proud
jen_payne
in reply to: hwalker
Hi
Thanks, So I've attached 2 files.
One showing the Block (which is 1239 wide)
The other showing when I insert the block it changes to 48.79 wide so much smaller.
pendean
1239mm = 48.77938 inches
It appears your destination file has INSUNITS variable set to 1, which is inches. Both of your posted DWG files are set to units=mm, so that one variable needs to change. Look up INSUNITS variable in HELP to set it to mm.
HTH
jen_payne
in reply to: pendean
Thank you so much! That has worked perfectly.
Thank you for your help
Forma Design Contest
Technology Administrators
