- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I am having an issue with AutoCAD LT 2016.
I draw my drawing in the modelspace including all text & dims. I then create a viewport on my drawing sheet/paperspace and set the scale of the viewport to the desired scale and zoom in to the area I want shown on the paperspace. Once this is done I revert back to paperspace.
My issue is once I have reverted back to paper space, I can see all of the modelspace Items including those beyond the extents of the viewport (It is like I have stuck a paper sheet behind the model space). This is mulitplied whenever I create mulitple viewports on the paper space, to the point where it becomes very difficult to work with.
This does not happen with all drawings that I work on, I have noticed that a common feature where I do have this issue is when the drawings have PDF XRefs attached, so i would presume that it is something to do with this but I am willing to be advised anyway to correct this.
Attached is a screenshot of my paperspace, which I have zoomed out so that you can see the extent of the modelspace visible. The viewport is the red box
I would appreciate if anyone can advise how to sort out this issue so that the items beyond the viewport boundary are not visible.
