AutoCAD LT Forum
What's wrong with this macro
9 REPLIES 9
Message 1 of 10
hwalker
465 Views, 9 Replies
^c^c^c_setenv;osnaps;$m=$(getvar,osmode);setvar "osmode" 32;-la;m;COVERMETER;;.text;mc;M2P;\;XX;layerp;-la;c;GREEN;COVERMETER;;setvar "osmode";$(getenv,"osnaps");
So the gist of it is I get my current snaps and then I change it to only intersection. Then I put some text onto a layer between 2 selected points. All good so far.
The problem is at the end. I want to get my previous snaps back and it doesn't work at all. HOWEVER it does save the correct binary value in the "osnaps" variable.
I've just tried it a few times and it "remembers" the previous setting for the variable and puts that in instead of the "current setting"
Howard Walker
Left Handed and Proud
9 REPLIES 9
Message 2 of 10
pendean
in reply to: hwalker
why not just set your OSMODE back to what your preferred setting is vs. trying to capture/retain what might not be your preferred setting in the first place? Using 1147 in this example as the preferred setting, my favorite default
^C^C_osmode;32;-la;m;COVERMETER;;.text;mc;M2P;\;XX;_layerp;-la;c;GREEN;COVERMETER;;_osmode;1147;
Message 3 of 10
hwalker
in reply to: pendean
Because I might send it to my fellow worker and her preferred settings might not be the same as mine.
Howard Walker
Message 4 of 10
steven-g
Difficult! The problem is that setenv doesn't get written into the variable until after the macro closes, which is why getenv is reading the old value. I would say leave the osnap value alone and use the command modifier 'int' before the pause for user pick points as it will only allow the intersection snap to be selected, but that is also a problem because the modifier 'm2p' only allows for one user pause in a macro but prompts for 2 pick points, the first point will indeed only select 'int' but the second point will accept any snap.
Message 5 of 10
pendean
@hwalker you might have to customize it for the other user in the interim until someone jumps in with something else to try.
Message 6 of 10
Paul_Gander
You will need a second nested macro expression enclosed in quotation marks so that the getenv function doesn't get evaluated until after setenv command has been executed. Try this:
^C^C^C_setenv;osnaps;$m=$(getvar,osmode);setvar;osmode;32;-la;m;COVERMETER;;.text;mc;m2p;\;XX;layerp;-la;c;green;COVERMETER;;setvar;osmode;"$m=$(getenv,osnaps)";
or alternatively, use the cal command to determine the mid point between two intersection snaps without the need to modify the current running object snap setting:
^C^C^C-la;m;COVERMETER;;.text;mc;'cal;(int+int)/2;\\\;XX;layerp;-la;c;green;COVERMETER;;
Message 7 of 10
hwalker
@Paul_Gander Your first solution is the one I needed. Cheers. The reason why I can't use the second one is I don't know which snaps my colleague prefers.
Howard Walker
Message 8 of 10
pendean
OSNAPCOORD (System Variable) set to 1 may be the answer you need https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Message 9 of 10
pendean
@hwalker A quick reminder that manually breaking/stopping the macro mid-process will not restore OSMOADE settings back to the user default before they triggered the macro.
Message 10 of 10
hwalker
No the person who will be using it knows how to use AutoCAD and it works just how I wanted it to now
Howard Walker
Technology Administrators
