Announcements
MACRO: Change Layer of Object
lukas.nagiller
lukas.nagiller
Hey guys!
I need your help please.. I'm new to macros and I need a macro which changes the layer of the current selected object(s) in AutoCAD LT..
And optional.. Maybe is it possible to check if an object is already selected with an "if" in the macro?
Please it have to be AutoCAD LT compatible.. No LISP..
Replies (8)
lukas.nagiller
Hey guys!
ВeekeeCZ
LAYMCH or LAYCUR are built-in commands that should serve your purpose.
h_s_walker
Use the CHPROP command.
CHPROP
Select objects: LAST 1 found
Select objects:
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: LAYER
Enter new layer name <STANDARD_TEXT>: REINFORCEMENT
The above changes the layer of the last object drawn
Also see the link below
CHPROP (Command) | AutoCAD 2021 | Autodesk Knowledge Network
Howard Walker
Left Handed and Proud
lukas.nagiller
Hi! Thanks for the really fast response.. unfortunately I can't get the macro to work rather I got not enough time to figure out how does this work.. and is there a method to check if on object is already selected or not?
Thanks for your help!
pendean
Community Legend
Community Legend
Select the objects.
Use the LAYER pulldown to change their layer.
Done.
Takes just as long to do as hunting and pecking at a macro button in LT. Try it.
h_s_walker
@pendean is the easiest way, but if you really want a macro
^C^C_.select \_.change previous ;properties layer reinforcement;
The above will allow you to select objects until you finish and will then change the layer to "reinforcement". Obviously you need to change "reinforcement" to your layer
Howard Walker
lukas.nagiller
I know I could get it from pulldown but we got like 200 layers in our company.. So to make the technicians life easier I make them a custom ribbon with the most important layers..
Thanks its working and my techicians will thank you!
pendean
Community Legend
Community Legend
@lukas.nagiller LAYMCUR or CLAYER then LAYCUR on the objects to "move" is the method we train our users to employ instead of hunting/pecking on a dozen+ custom macro buttons in a unique panel or toolbar: they learn AutoCAD in the process too.
You might want to teach them to use SETBYLAYERMODE (System Variable) as well to "fix" blocks that don't conform.
Those buttons already exist.
HTH
