AutoCAD LT Forum
What is the correct way to edit constant attribute definitions within a block?
1 REPLY 1
johnrmcwatersiii
925 Views, 1 Reply
I inserted two attribute definition within a title block, one for a project's name and the other for the project's address. I would like these attributes to be the same in all the references of the block, so I set them to constant. However, when I double click on the block to bring up the enhanced attribute editor window, the constant attributes are not showing. Is there a correct way to go about editing these attributes within the block?
1 REPLY 1
cadffm
in reply to: johnrmcwatersiii
Your doubleclick (enh.attribut editor) can edit Attributes, Attributes are part of Blockreferences, not part of a block.
Your (none constant) Attributdefinitions inside your Block are just templates for Attributes for new inserts.
Constant Attributdefinitions are not more like a Text or Mtext in a Block,
so the right way to edit is BEDIT.
And now you can re-think about your choice:
Would you also use Text(inside the Block) for projectname and adress?
If your answer is No, because of..
then constant attribut definitions are not the best choice for you.
Difference between Text an const.Attdef: You can extract constant attdefs, thats all.
Sebastian
Forma Design Contest
Technology Administrators
