Weird Layer Lock Issue in CAD LT 2013
Hi!
I don't really know how to explain my issue and hence can't search for solutions but let me explain what I am battling with.
I don't know how it happened but somehow while I was drawing some lock function must have turned on.
I am in model space and have a floor plan consisting of many different layers. I can select any line from any layer drawn and it becomes highlighted, but it all shows up as being part of one layer i,e 5 even if it was drawn as layer 2. If I select a line (that shows as layer 5, I try chnage its color, its linetype - it shows it has chnaged in the property toolbar, but in reality in model space it remains unchanged.
If I select an object first and then say try and move it, 'm' & enter - it uselects and I get that square box whith a popup message, select objects. If I do so and enter, I can the move the object.
In the layer property tab - nothing is on lock or freeze or off. I can switch between layers but then as before everything I select on the drawing shows up as this new layer.
What did I press and how can I go back to normal?!
Thanks IN ADVANCE!
fEIGE
pendean
Community Legend
Community Legend
Type PICKFRIST and the command line and set it to 1.
Thank you so much! That worked! How does that happen?
