Plot to File Default Filename
JLeeSaxon
Message 1 of 12
JLeeSaxon
In R2013, the default file naming convention for plotting to a file (jpg, pdf, etc) was [your dwg's filename].pdf
This was ideal for me.
Since R2013 SP1 (including R2014, which I've just moved onto), it has changed to [your dwg's filename] [name of the sheet you're plotting].pdf - as in "DSMC-AS-L Model(1).pdf" instead of "DSMC-AS-L.pdf"
I don't like that at all. Having to manually change it every time is pretty obnoxious.
Is there an way to change this?
Lee Saxon
Ellis Photographic Design
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
AutoCAD has always done the latter: so unless it was a quirk in only 2013 before the patch, did you lose a customization that created the former? AFAIK it's all or nothing in AutoCAD, nothing means no name is auto-assigned at all.
Message 3 of 12
Charles_Shade
Are you using DWG to PDF or a third party PDF driver?
Message 4 of 12
It is the same way in 2010 with plotting to pdf.  Now if you use the EXPORTPDF, it will do what you're looking for <drawing name>.pdf.  AFAIK this has always been the functionality of plotting to pdf, and I'll see if I can explain why this may be.  There are many industries that have many layouts in the same file.  AutoDesk put this naming scheme (<drawing name> <layout name>.pdf) in place for those who plot multiple layouts to pdf from the same file.  If they hadn't, then you can see what a mess it would have made.  Plotting 3 layouts to pdf would have resulted in only 1 pdf.  HTH
(if ("mysolution"=answer) then (click "Accept As Solution"))
Message 5 of 12
JLeeSaxon
Thanks to this post, I realized what happened. I was using "Adobe PDF," which comes with Acrobat, instead of "DWG to PDF." The change I experienced was probably due to an update to Acrobat rather than AutoCAD.
By the way, don't use Adobe PDF. It has a bug in the way it handles wipeouts, causing them to plot (as a frame with some printers, as a solid block with others) even if you have frames off.
Lee Saxon
Message 6 of 12
JLeeSaxon
@Anonymous wrote:
...for those who plot multiple layouts to pdf from the same file.  If they hadn't, then you can see what a mess it would have made...
Definitely, that makes sense. I wish they'd make a system variable for this, though, with <drawing name> <layout name> the default and just <drawing name> an option. Maybe even allow custom naming conventions.
Lee Saxon
Message 7 of 12
What kind of naming are you looking for?  I'm sure something could be cooked up with a macro and diesel.  Unfortunately LISP is not available to LT users otherwise I'd go that route, but some pretty good things can be done with just a macro and Diesel.
Message 8 of 12
Jozi68
Does anyone know of a LISP routine for this?
I have to use DWG To PDF.pc3, as it is the company standard.
However, I don't want <drawing name> <layout name> as the default,  I just need <drawing name>
Message 9 of 12
pendean
Community Legend
Community Legend
No LISP in LT: are you in the wrong forum?
Message 10 of 12
If you use the "Publish" Command the wipeouts are just fine, otherwise you get that black blob on paper (But it looks just fine in PDF viewers).
Message 11 of 12
looking for the same thing. I want to plot just the dwg. name, not the layout too.
Message 12 of 12
maratovich
Lisp does not work in LT.
Or do you have the full version?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
