I am using Autocad LT 2018 and have been successful in using the Wacom intuos4 PTK-640 as a pointing/mouse device and have been able to use it as a table. However when i try to calibrate and use the table as a digitizer the drawing of lines are not proportional or accurate. I created a 1" x 1" grid to calibrate the tablet but it doesn't draw to 1" to 1" scale and the x drawn line isn't the same length as the Y drawn line. The Y drawn line is longer than the X drawn line.
I an trying to digitize hand tools to be able to create drawings and then be able to make a CNC program to cut the tools out of hard plastic for a shadow board tool holder.
Any one have any good suggestions how to complete this task?
Solved by pendean. Go to Solution.
when I type tablet into Autocad I get "Tablet Enter and option [ON OFF CAL CFG] :
all four of the commands are valid and usable.
Years ago I was able to use a summagraphics tablet to be able to digitize drawing and trace/sketch around items to get a proportional drawing that I would then clean up and create an accurate drawing. I didnt know if this was still an option.
if it isnt a valid option then why does the tablet calibrate command still exist?
if the X and Y coordinates was proportional I could use the scaling method to adjust the size.
Any other suggestions/methods for digitizing?
Hello @mention,
Welcome to the Autodesk Community!
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Checking back with you on my previous post if you have any questions or found a workaround post back with any new updates.
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
