I just recently upgraded from LT 2010 to 2015 and right off the bat noticed my Viewport buttons are disabled on the panel and have to type in the viewport command to initiate. Any ideas?
Solved by TriCityGlassman. Go to Solution.
Which 'viewport" button(s) exactly are you selecting? the ones for paperspace layouts are grayed out when not in a layout tab, the ones for modelspace are only present when you are in a modelspace tab.
VIEW tab for modelspace, LAYOUT tab for paperspace 'viewport' buttons: where are you clicking?
Hi Dean,
Please see the attached. I'm in paperspace and not able to select a new viewport button and instead need to type in "viewport". I'm a complete novice to Acad but when I had 2010, I simply went to the view ports tab and selected new.
