Version change log from 2008 to 2017 and most inbetween...!!!
neilyj666
Mentor Mentor
Message 1 of 9
neilyj666
I'm updating the company template to comply with the UK BIM Standards and we have users on various versions of LT as shown below
LT2008 – 2
LT2009 – 1
LT2010 – 2
LT2012 – 2
LT2014 – 1
LT2016 – 14
LT2017 – 2
I'm creating the template in 2016 and am using dynamic blocks, fields etc etc but realise that not all features in later versions are supported in earlier ones so does anyone know if there is a published changelog showing when the various features were added to LT?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (8)
Message 2 of 9
Justin_Doughty
Hi neilyj,
The only thing I have is the attached, its for Full AutoCAD though. might help.
Justin Doughty
ARKANCE
Message 3 of 9
neilyj666
Thanks for this @Justin_Doughty - it  certainly gives me a good start...:)
Message 4 of 9
Emmsleys
@neilyj666, See the BOX attachment and let me know if that helps.
Sarah Emmsley
Technical Support Specialist
Message 5 of 9
neilyj666
@Emmsleys - I can't see an attachment....
Message 6 of 9
Emmsleys
It should be in the BOX invite I sent you, that you accepted.
I'll add it here as well in case @Justin_Doughty needs it too.
Sarah Emmsley
Message 7 of 9
Emmsleys
Post back and let me know if you are unable to access the BOX or download the spreadsheet.
Also, it is a collection of all the commands/sysvariable on both AutoCAD and AutoCAD LT. You will need to look to column C.
Let me know if this helps or if you have questions.
Sarah Emmsley
Message 8 of 9
neilyj666
Ah yes I see it now...:)
Message 9 of 9
Emmsleys
Hopefully it helps  Smiley Happy
Sarah Emmsley
