VBA with AutoCAD LT
VBA with AutoCAD LT
Message 1 of 17
VBA with AutoCAD LT
Hi alls,
Does AutoCAD LT support VBA?
Is there an API to access and manipulate DXF "externally" from .NET environment (C# or VB)?
thanks,
GC
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
Autodesk does not make VBA customization available in LT.
Message 3 of 17
h_s_walker
As Dean said. HOWEVER you can run a vb exe program in LT by creating a button with the following in it ^C^C_ai_startapp yourprogram.exe But you need to make sure that yourprogram.exe is in the Base AutoCAD directory.
Howard Walker
Left Handed and Proud
Message 4 of 17
Thank you Dean and HWalker.
Is there any API and classes for use in this MyProgram.exe?
Message 5 of 17
h_s_walker
Send me via PM your email address and I will email you a VB6 program I wrote with some help, which draws closed polylines (steel shapes) in autocad
Howard Walker
Message 6 of 17
h_s_walker
Check your emails. I've sent you my program
Howard Walker
Message 7 of 17
h_s_walker
The other email address you gave me is being rejected. So I'm attaching the zip file here
Howard Walker
Message 8 of 17
steven-g
NIce, I'll be trying to figure out how that actually works for the next few months, (how it communicates with LT that is), I thought all external communication was disabled except for scripts.
Message 9 of 17
h_s_walker
Dynamic Data Exchange (whatever that is)
Howard Walker
Message 10 of 17
steven-g
Yup got it, I just drew my first line directly from excel VBA, as I said this will keep me occupied for months now. Smiley Very Happy Thanks
Message 11 of 17
Great !
What class package do you use? DDE? Where do I find it?
Sincerely,
Gady Cohen
Template Project Manager
VoyantHealth(tm)
Gady.Cohen@brainlab.com
Phone: +972 (3) 929-0935
www.voyanthealth.com
www.brainlab.com
[cid:image001.gif@01D004C1.62D6FC00]
Message 12 of 17
h_s_walker
Have you downloaded the zip file?
If you have search it for the text LINK. There are several LINKMODE,  LINKTOPIC and LINKEXECUTE.
If you find those and see how I've used them in the program you should be able to work out what to do
Howard Walker
Message 13 of 17
I want to modify block attributes autocad LT with vba (list of data from excel sheet). It's possible in Autocad (I have programming it and it works) but doesn't work in LT (it doesn´t support LISP, neither VBA) 😞
Can you help me?. Thanks.
Message 14 of 17
h_s_walker
Unfortunately not. BUT I would start by looking at the following link which tells you how to link to data from an external source
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Howard Walker
Message 15 of 17
Emmsleys
AutoCAD LT has limitations and this is one of them.
I'd recommend you for you to leave your feedback here: http://www.autodesk.com/company/contact-us/product-feedback
Sarah Emmsley
Technical Support Specialist
Message 16 of 17
can you please share Code for me my mail id Vinay.moogi777@gmail.com
Message 17 of 17
h_s_walker
Check my replies on the previous page you will find all the information you need and a file called steel.zip as well
Howard Walker
