AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
unhandled access violation reading 0x0010 exception at e3207b12h
2 REPLIES 2
673 Views, 2 Replies
I have a PROBLEM
Please help
2 REPLIES 2
jayhar
1.  Send your error report, you can get CER_0000000.....contact Customer Support to follow up on this issue, provide the error report number for tracking purposes. check mail
2. Repair corrupt AutoCAD files command EXPORTTOAUTOCAD, WBLOCK & RECOVERALL.
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
ChrisPreece
Hi @Anonymous,
I see that you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestion that @jayhar provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily. If not, did you have a chance to submit a crash error report yet? If you are able to submit a report, I will look it up on my end and see if I can identify any potential causes of the fatal error.
Chris Preece
Technical Support Specialist
Technology Administrators
