AutoCAD 2014 LT Ribbon problem
This widget could not be displayed.
I have a problem with ribbon. After opening a file there is no ribbon.
 Command "_ribbon" isn't working.
When I open program by icon,  I can choose workingspace "Drawing & Annotation" and it works, but in concrete file it doesn't work. I don't know what to do, I was trying everything - CUI options, creating new working area. It doesn't work. It work only Classic workingspace, but i have always work with ribbon...
It start happend after system reinstalling (Windows 10).
Please help me
jayhar
1. Double Click on Top Panel. find the attachment
2. Or, Enter the CUILOAD command, select the ACADLT.CUIX file and then click Load.
3. Or, reset CUILX Click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
ChrisPreece
Hi @Anonymous,
I see that you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestion that @jayhar provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
