I am currently unable to insert images into my drawings on LT 2018. I have tried a variety of images with the same result. Also into Paper space and model space.
I notice the same problem is occuring with my old 2009 software and also old files with inserted images aren't displaying.
I did try inserting an image into a MS word document, in case that was relevant, and it did work.
Any possible solutions appreciated.
What command are you using?
Are you trying to insert them onto a layer which is switched off?
Howard Walker
Howard Walker
Insert/Attach/All images
I have just opened up a new drawing and attempted to insert image still nothing. (All layers on)
Have you chosen the insertion point of the image?
Can you post a Screencast so we can see the steps you're going through.
Howard Walker
Howard Walker
Thanks but typing in the command doesn't make any difference.
Apologies I have now attached the file. As I said its not really about the file as I have tried a variety of
images files.
images files.
That's not a file from the folder in your video
The one you just posted works fine here
What does ABOUT command report your 2018 version to be exactly? Post a screenshot of that pop-up.
Please find About screen print attached.
Mysteriously the attach feature has started working fine. I can only assume it
was an issue with my computer as it only stopped working for a few days.
Thank you to anyone who took the trouble to try and resolve the problem.
This morning upon opening a drawing file with previously successfully inserted jpeg images (2) I found that only
an outline and folder address was displayed. I tried to load the images in the normal way but came up with an error message so tried changing the file name and they inserted successfully
If anyone has experienced anything similar and may know the reason I would be grateful for your advice.
Hi Pendean thanks for your help.
No files were moved.
