@jeffK9B4B Are you by chance new to AutoCAD in general if I may ask? The alert says LOCKED layers, not "frozen" layers, two different items
Or are you just anting all pop-ups to disappear forever because you, like most of us here, know what you are doing and don't need the program to remind you all the time? Sadly, if you don't find a setting in the EXPERT System Variable for this latter need, it does no exist in the program.
If you wish to find a selection method or tool that will filter locked layers for you (frozen are always ignored, nothing special is needed), you'll have to customize with LISP code that you write yourself in LT2025 if someone does not have something like this written, then load and use that (and never a core selection tool) all the time. At a quick glance, I'm not sure QSELECT or FILTER commands do that.
HTH
