Turning off warning bubble
jeffK9B4B
jeffK9B4B
Howdy all
I was wondering (hoping), there was a quick select that allowed me to disable this rather annoying pop up i get when I select all and change everything to a selected layer, excluding the layers i have frozen. I use AutoCAD LT 2025
Any advice welcome....
Cheers
paullimapa
One sure method would be to unlock all layers
Paul Li
IT Specialist
@The Office
RSomppi
@jeffK9B4B wrote:
Howdy all
Cheers
The warning is about locked layers. Your question is about frozen layers. Please clarify.
pendean
Community Legend
Community Legend
@jeffK9B4B Are you by chance new to AutoCAD in general if I may ask? The alert says LOCKED layers, not "frozen" layers, two different items
Or are you just anting all pop-ups to disappear forever because you, like most of us here, know what you are doing and don't need the program to remind you all the time? Sadly, if you don't find a setting in the EXPERT System Variable for this latter need, it does no exist in the program.
If you wish to find a selection method or tool that will filter locked layers for you (frozen are always ignored, nothing special is needed), you'll have to customize with LISP code that you write yourself in LT2025 if someone does not have something like this written, then load and use that (and never a core selection tool) all the time. At a quick glance, I'm not sure QSELECT or FILTER commands do that.
HTH
jeffK9B4B
Thanks all for your messages, but it seems I didn't know the difference between FREZZE and LOCK layer.....now I do.
Once I froze the layer and then did SELECT ALL -> change layer to preferred layer, that pop up message did not appear.
Happy days!!
Cheers
