AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
TRIM and ERASE out in a ellipse
3 REPLIES 3
468 Views, 3 Replies
Hello.
I need a TRIM and ERASE out in a ellipse for all the lines outside. It must be scripted because there are multiple files. Can help?
thank you.
3 REPLIES 3
pendean
There is no automation at that level in LT.
Post a screenshot of a BEFORE and AFTER and maybe someone can suggest a more realistic down-to-LT-level help to get you speeded up at least.
steven-g
If it is always in the same place and same size ellipse then it shouldn't be a problem. Post a drawing and as pendean has said someone can maybe offer some pointers. When you say scripted, I have in mind an Autocad LT script, but you will have to run it yourself with each file. Though I do believe it is possible to run a windows command script on multiple autocad files it has been many years since I did anything like that.
Emmsleys
Circling back to your thread, were you able to find a work around? If you still have questions post back in the thread.
Thanks.
Sarah Emmsley
Technical Support Specialist
Technology Administrators
