Command Question
Command Question
lbellino4
Command Question
lbellino4
Hello.
Not sure if there is another post out there on this subject, since I wasn't sure what it would be listed as. But I'm trying to find a way to turn off the cursor notes when in a command (see image attached with the red circled item.) When I opened my ACAD today, it started showing these, where before these were off, so not sure how this changed. Any help is much appreciated. Thanks.
sthompson1021
Easy way is to hit the F12 button. It's called Dynamic Prompt that you are seeing. Look up DYNMODE in help to explore the options.
lbellino4
Thanks...that did the trick!
