Text rotate problem
Text rotate problem
Text rotate problem
Text is placed Horizontal, it is impossible to rotate by 90 Degrees or any degrees. It will always stay on 0 Degrees
ValdisPriednieks
You can simply use Rotate function.
There is Single Line Text. Single Line Text icon -> left mouse button in place, when You want start text -> Enter -> type angle (for example 90) -> Enter -> type Your text (text is still horizontal) -> Enter Enter
You will see, Your text became rotated.
That is all.
pendean
Community Legend
Community Legend
You can rotate it after the fact as noted above:
https://www.youtube.com/watch?v=Q-K9U1QRLSw
If you are looking to rotate the text before you type in the content,then watch the commandline as you start TEXT or MTEXT command and see what is on offer.
That is what I was thinking but doesn't work.
After some more research:
In TEXT Style window, and "size" the box "Match text orientation to Lay-out" was clicked.
After turning it off, all is fine
Thanks Valdis
ValdisPriednieks
There is another comfortable method. Horizontal text. Right mouse click on text -> Properties or Quick properties -> Find Rotation -> Change rotation angle from 0 to Your angle (for example 60) -> Enter. The text will be rotated.
