Migrate Custom settings
h_s_walker
Mentor Mentor
Message 1 of 14
h_s_walker
First things first. I know how to migrate settings. Now onto the problem. Every time I try I get the following error. "An error occured during the exporting process. Please try again." "ERROR: There was an error generating the XML document" LT2012 on a Windows XP machine. Does a
Howard Walker
Left Handed and Proud
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
Your post got cut off... .
Looks like either the tool or the content it is trying to create is damaged, from the snippits you posted. You cannot fix the tool without a removal and reinstall which may damage what you are trying to migrate.
Message 3 of 14
h_s_walker
I just asked if anyone knew how to fix it.
Howard Walker
Message 4 of 14
Albert_Rius
Can you check if updating/Reinstalling the Microsoft XML helps?
To do this, go through Add or Remove Programs and uninstall everything that starts with "MSXML" and then download and install both of the following:
MSXML 4.0 Service Pack 3 (Microsoft XML Core Services)
Microsoft Core XML Services (MSXML) 6.0 Service Pack 1
I hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
Message 5 of 14
h_s_walker
Unfortunately that didn't work. I still get the error. BUT here is the question now. Do I need it?
It creates a zip file which I cannot open using Windows (I get a blank explorer screen) However using WinRar shows me relevant directorys and files.
Howard Walker
Message 6 of 14
Albert_Rius
Please can you provide more information about from what release do you what to export and the release to import?
Are they installed in the same machine?
Are the same language?
The error message appears when you export or when you import?
Albert Rius
Technical Support
Autodesk, Inc.
Message 7 of 14
h_s_walker
I'm only trying to export to create a backup. The error is written exactly as I see it in my original post.
Using Autocad LT 2012 on a Windows XP machine.
Howard Walker
Message 8 of 14
pendean
Community Legend
Community Legend
If I may... what is it you want to backup exactly? Be specific, otherwise for a generic "backup" your PC should have that in place already. Right?
Message 9 of 14
h_s_walker
No our system is full of holes Dean. I've have custom tabs and plotter styles, which I know "Migrate custom settings" collects. I am trying to get a backup of these without having to hunt everywhere for them.
Howard Walker
Message 10 of 14
Albert_Rius
If the Zip file is created, can you try to import it in a different machine to see if the migration data was created correctly?, the XML error can be from the XML report visualization of the data migrated, that will not affect the data exported.
Albert Rius
Technical Support
Autodesk, Inc.
Message 11 of 14
h_s_walker
I shall have to wait to try that. I don't have another machine with LT2012 on it here at work
Howard Walker
Message 12 of 14
Albert_Rius
You can just create a new Windows user on the same machine, log in with it and try to import to check if all migration was succesfully....
Cheers
Albert Rius
Technical Support
Autodesk, Inc.
Message 13 of 14
h_s_walker
Just tried and got an error "This file is not an Autocad LT 2012 English migration package"
Howard Walker
Message 14 of 14
Albert_Rius
This error means that the package was not created succesfully. Probably will be a good idea to run a repair in your AutoCAD LT 2012 installation and try to generate again the zip file.
Albert Rius
Technical Support
Autodesk, Inc.
