AutoCAD LT Forum
TEXT MASK ON DIMENSION TEXT
18 REPLIES 18
Message 1 of 19
55297 Views, 18 Replies
Hello.
I have a dim on top of a hatch - trying to mask dim text - selected dimension, changed fill color to BACKROUND, sent hatch to back, brought dim to front AND above object. Mask looks great in Model Space, but no mask in Paper Space. Any ideas??????
18 REPLIES 18
Message 2 of 19
pendean
Show us your dwg with the layout issue in place.
Message 3 of 19
john.vellek
Hi @Anonymous,
Try doing it this way. Open your dimension style and select the Text tab. Select Background for Fill Color.
See if that performs the way you like.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 4 of 19
john.vellek
Hi jason.roth,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Message 5 of 19
in reply to: john.vellek
That did it. Thanks for the help
Message 6 of 19
Great solution!  Fast - direct - successful.  Thank you!
@john.vellekwrote:
Hi @Anonymous,
Message 7 of 19
codee
in reply to: JosephKowalski
You can do it with an override so you don't have to change the entire dim style in the properties panel.
Message 8 of 19
in reply to: codee
Is there a way to have it keep the dim line if there is text on both the top and bottom of the dim line?
Message 9 of 19
yes i would to know how to fix the issue where the background fill covers the dimension line after you put in text on the bottom. it only does this to me when i use the radius dimension on solid parts. if i do this on 2D line it works fine.
Message 10 of 19
in reply to: codee
With the "Background Fill" for dimension text, is there an equivalent to text mask "Border Offset Factor?"
I don't want so much space around the dimension text to be masked...
Thanks 🙂
Message 11 of 19
pendean
No option.
Message 12 of 19
in reply to: pendean
@pendean Well that sucks, but it's good to know. Thanks for the reply!
Message 13 of 19
snava66MUX
Hello All:
I just learned this this morning. There is a fix for the issue of the dimension mask for the 2nd text line covers the dimension line. This has been an issue for as long as i can rememeber.
are you ready for it.... ?
DIMTEDIT , then set to centered
Message 14 of 19
good one mate!
Message 15 of 19
rlewis6J8RM
in reply to: snava66MUX
Been trying to find a solution to this for the longest time... Thank you!
Message 16 of 19
So I clicked on the dimension and went to the change menu to set the background color so I can mask the text. Unfortunayely my system froze and I had to CTRL-ALT-DEL to get out of Autocad. Is this a proper solution?
Message 17 of 19
h_s_walker
If you're talking about how to have a mask for dimension text, yes that is the proper solution
Howard Walker
Left Handed and Proud
Message 18 of 19
in reply to: h_s_walker
Thanks, wanted to be sure. It worked after I rebooted Autocad, 1st time everything froze.
Message 19 of 19
mikeVLJRL
I had this same issue and this tip worked great!  Thanks!
Technology Administrators
