AutoCAD LT Forum
Text comes out jagged in published DWFx files
3 REPLIES 3
92joaotome
189 Views, 3 Replies
Hello everyone, I have been searching the web and i can't find a solution to my problem
When I publish a DWFx file the text comes out all jagged up (print for reference). I noticed that on the DWFx ePlot.pc3's custom properties there is no reference to "Font handling" i suspect the problem may be related to this but i can't find a fix
If any one knows a solution to this issue i would be very gratefull
Also some colleagues can publish the same dwg file just fine, I also tryed whit diferent dwg files and i get the same jagged text
Thank you in advance
Best regards
João Tomé
Tags (3)
Labels (3)
3 REPLIES 3
pendean
in reply to: 92joaotome
@92joaotome Are you and your colleagues using the same exact LT version? and that is what for each of you as listed by ABOUT command from inside each program?
And the same exact settings for the DWFx driver?
Not seeing any issues at all here, we use TTF fonts and AutoCAD/LT is not reporting any missing fonts or making any substitutions
92joaotome
in reply to: pendean
Hi!
So my version is U.63.0.0 AutoCAD LT 2024
I can't tell what my colleagues are using because I don't really know, same for the DWFx driver
Is there a way i can get a new DWFx driver?
pendean
You can reinstall LT2024 nd this time avoid migration from an older version.
You are also missing this update
Technology Administrators
