AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Batch plot
5 REPLIES 5
kberroJR2MV
149 Views, 5 Replies
Batch plot
I am having issues batch plotting it gives me the error that the device wasnt found.
5 REPLIES 5
hwalker
in reply to: kberroJR2MV
What is the printer named in your page setup and is that exactly the same name as it is installed on your computer?
Howard Walker
Left Handed and Proud
kberroJR2MV
in reply to: hwalker
yes
hwalker
Can you post images of both.
The only reason why it says that is either the device is not plugged in or they are named slightly differently?
Actually is it on a network? The other way it might not find the device is if the IP address has changed.
Howard Walker
pendean
Why not try a different pagesetup, or better yet, why not PUBLISH to PDF then try to print from there to your Ricoh to see the correct name of the device and confirm it is working first @kberroJR2MV
paullimapa
I assume you disabled background printing?
Paul Li
IT Specialist
@The Office
Technology Administrators
