AutoCAD LT Forum
synced drawing misaligned and shifted
13 REPLIES 13
Message 1 of 14
1055 Views, 13 Replies
AutoCAD Support,
I am having some syncing issues with our CAD drawings. The two images I attached are the same drawing opened at the same time: one is my screen and the other is my coworker's. If you notice, my coworker's screen shows the drawing with lines misaligned. My screen does not. How do we sync these drawings? Help.
13 REPLIES 13
Message 2 of 14
pendean
This is not Autodesk Support: for that you need to log into your Subscription Page and do the following:
What versions of LT are you both using?
WIndows OS version you both are using?
By chance does changing the CANNOSCALE setting fix the problem?
Can you share this dwg file for someone here to look at?
Message 3 of 14
in reply to: pendean
2015
I am using Windows 10 Pro x64
Coworker is using Windows 7 Pro x64
How can I go about changing the CANNOSCALE? Sorry, I am new to AutoCAD.
Message 4 of 14
That other file is failing to open correct. Here's this one
Message 5 of 14
user181
You can change the CANNOSCALE at the bottom of the screen. See picture below.   Also select the drawing that is referenced into your drawing and on the properties palette make sure the insertion point X, Y & Z  are 0
Message 6 of 14
in reply to: user181
Okay, I set all the references' insertion point X Y & Z values to 0.
Message 7 of 14
user181
If the xref insertion point is the same on both computers and one still visually shows it incorrectly than I would suggest you look into if your computers video card is certified for your Autodesk product. Here is a link http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
You can try disabling the hardware acceleration with the -GRAPHICSCONFIG command.
Message 8 of 14
My video card is certified and both files' scale is the same.
Any other possible solutions?
Message 9 of 14
user181
Sorry, I'm out of ideas why they would appear different. Maybe someone will come along that has had this issue before. Good luck.
Message 10 of 14
pendean
I need to ask one more time: what exactly is the issue?
Or is it the fact that the W file you posted has items floating far away on both sides while in the other file it does not?
Message 11 of 14
The issue is that my coworker's file isn't rendering it like it does on my computer. The scaling is the same. The only thing is different are the graphic cards. They're aren't aligned like they are on mine.
Message 12 of 14
pendean
Do you mean these double-images?
Is this the only file having this issue?
Message 13 of 14
Yes that is correct!
And yes, this is.
Message 14 of 14
pendean
You only posted the DWG file with the bigger items that are not blocks but plines: since this uploaded file is reporting a missing XREF, perhaps one of you is opening the wrong XREF file at the partial location of .\X-LOONEY ELEVATIONS.dwg.
There seems to be a bigger story or a lot more files in question that you are not sharing.
Technology Administrators
