Hello.
Pressing the big gray 'start drawing' Icon on the 'get started' screen does not open a template, but instead an already existing drawing. How can I change this back to normal?
/ Anders
Has somebody accidently saved a drawing as the template?
Howard Walker
delete all the stuff from the drawing which is not supposed to be in the template drawing and then resave it as a template
Howard Walker
Thanx to you all for yor support - the issue sort of - somehow - solved itself:
I shut down and re-opened AutoCad; same problem.
I repeated this 4 or 5 times, and then, suddenly
Everything is back to normal, and I have not a clue...
Thanx anyway for your commitment.
/Anders
