I've been saving and opening drawings to web and mobile from inside of AutoCAD LT 2019. I have many drawings saved and want to clean them out / delete and maybe even manage folders. Where do I access such functions? It seems that LT will only let me open or save to web/mobile but not delete or manage.
Solved by Tiana_Y. Go to Solution.
Solved by pendean. Go to Solution.
Hi @jeff,
I have added a link that explains the File Management for the AutoCAD Web App, which has where to find how to delete/manage files. If you have shared folders, this may be why you are unable to manage, as others might be using or have ownership of that folder. I also added the Help page with how to manage your folders/files in the AutoCAD Mobile App, as well. I hope this helps! Please let me know if you have any other questions.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
