Specs for new computer
goofygirl
goofygirl
Good morning,
I need to purchase a new laptop.  I would like to stay with the Thinkpad.  There are so many and I have looked at the LT specs for CAD LT and Revit LT and for the most part I can decipher however when it comes to graphic cards I am not confident.  Can someone take a look at the specs below for a model I am interested in and let me know if this will serve me well?  The one I have now has lasted 11 years!  I've even dabbled in revit on it.  Thank you in advance.
Tech Specs
Processor Operating SystemDisplayMemoryBatteryStorageGraphicsSecurityAudioCameraDimensions (H x W x D)WeightColorCertificationsConnectivityPorts & SlotsKeyboardSupported DockingWhat's in the boxMore Information
  • 11th Generation Intel® Core™ i5-1135G7 Processor (2.40 GHz, up to 4.20 GHz with Turbo Boost, 4 Cores, 8 Threads, 8 MB Cache)
  • 11th Generation Intel® Core™ i5-1145G7 Processor with vPro® (2.60 GHz, up to 4.40 GHz with Turbo Boost, 4 Cores, 8 Threads, 8 MB Cache)
  • 11th Generation Intel® Core™ i7-1165G7 Processor (2.80 GHz, up to 4.70 GHz with Turbo Boost, 4 Cores, 8 Threads, 12 MB Cache)
  • 11th Generation Intel® Core™ i7-1185G7 Processor with vPro® (3.00 GHz, up to 4.80 GHz with Turbo Boost, 4 Cores, 8 Threads, 12 MB Cache)
  • Windows 10 Pro
  • Windows 11 Pro
  • 14.0" WUXGA* (1920 x 1200) IPS, anti-glare, touchscreen, low-power, 400 nits
  • 14.0" WUXGA (1920 x 1200) IPS, anti-glare, low-power, 400 nits
  • 14.0" WUXGA* (1920 x 1200) IPS, anti-glare, touchscreen, PrivacyGuard, 500 nits
  • 14.0" WQUXGA (3840 x 2400) IPS, glossy, HDR 400, 500 nits
Screen to body ratio = 86%; aspect ratio = 16:10
*All FHD screens include 100% sRGB.
Up to 32 GB LPDDR4x 4266MHz
  • Up to 16.7 hours* 57Whr (MM18)
  • Rapid Charge (requires 65W PSU or higher)
*All battery life claims are approximate and based on results using the MobileMark® 2018 battery-life benchmark test. Actual battery life will vary and depends on many factors such as product configuration and usage, software use, wireless functionality, power management settings, and screen brightness. The maximum capacity of the battery will decrease with time and use.
Up to 1TB PCIe SSD
Integrated Intel® Iris® Xe Graphics
  • Discrete Trusted Platform Module (dTPM) 2.0
  • Optional: Human-presence detection sensor with IR camera
  • Smart Power On fingerprint reader integrated with power button (match-on-chip)
  • Webcam privacy shutter
  • Kensington lock slot
  • Dolby Atmos® Speaker System
  • 4 x 360-degree far-field microphones
  • Dolby Voice® professional conferencing solution
  • 720p HD with webcam privacy shutter
  • Optional: Hybrid infrared (IR) / 720p HD with webcam privacy shutter
  • Optional: Hybrid infrared (IR) / 720p HD with webcam privacy shutter and Human Presence Detection
14.9mm x 314.5mm x 221.6mm / 0.59" x 12.38" x 8.72"
Starting at 2.49 lbs (1.13 kg)
  • Black
  • Optional: Carbon-Fiber Weave on top cover*
*Available on all UHD+ displays
  • Energy Star® 8.0
  • EPEAT® Gold
  • Optional: WWAN: Quectel EM120R-GL 4G LTE CAT12 No eSIM
  • Optional: WWAN* Qualcomm Snapdragon X55 5G Modem-RF System
  • Intel® AX201 Wi-Fi 6  802.11AX (2 x 2)
  • Bluetooth® 5.1 or above
  • with vPro®: on vPro® processors
* Optional WWAN availability varies by region and must be configured at time of purchase; it requires a network service provider. 4G available Spring 2021. 5G available May 2021.
  • 2 x USB 4 Type-C with Thunderbolt™ 4 (DisplayPort / Data Transfer / Power Delivery)
  • 2 x USB-A 3.2 Gen 1
  • Headphone / mic combo
  • HDMI 2.0
  • Optional: Nano SIM slot
USB port transfer speeds are approximate and depend on many factors, such as processing capability of host/peripheral devices, file attributes, system configuration and operating environments; actual speeds will vary and may be less than expected.
Blacklit - US English
  • USB-C Dock
  • ThinkPad Thunderbolt™ 4 Dock
Docking stations sold separately.
  • ThinkPad X1 Carbon Gen 9
  • 65W AC Adapter
  • 57Wh Internal Battery
  • Quick Start Guide
Full spec list for part numbers starting with 20XW available here
*Not all specs available on lenovo.com
pendean
Community Legend
Community Legend
Greetings @goofygirl
REVITLT2023 system requirements are what will matter here for you, and they are quite specific: Lenovo Sales (sign up for free and go through the LenovoPRO Small Business Store) they can help you decipher which you need, here is the link to share with them and for you to review HERE
In my experience and opinion, the "Integrated Intel® Iris® Xe Graphics" is just not going to cut it long term as your only graphics card use.
goofygirl
Thank you.
