snap setting
snap setting
chlrjsgh555
Message 1 of 12
snap setting
chlrjsgh555
The command window should appear so that snap can be set, but the snap window appears.
How do I make the changes so that I can change the settings in the command window?
Replies (11)
Message 2 of 12
paullimapa
+DSETTINGS
2
will give you this:
+DSettings
0
will give you this:
Paul Li
IT Specialist
@The Office
Message 3 of 12
RSomppi
It's the same dialog box (window). Just switch tabs.
Message 4 of 12
pendean
Community Legend
Community Legend
@chlrjsgh555 Show us what you see please: post a bunch of screenshots.
Message 5 of 12
chlrjsgh555
The Snap window pops up right awayThe Snap window pops up right away
The snap window pops up right away
'CAD Lisp' is not available.
I want to change the settings in the command window like thisI want to change the settings in the command window like this
Message 6 of 12
paullimapa
Do you type at the command prompt SNAP and that's how you see this?
What command do you enter to bring up this SNAP Drafting Settings window?
So is your question to change something so that you always see the SNAP at the command line but not in the Drafting Settings window?
Paul Li
IT Specialist
@The Office
Message 7 of 12
chlrjsgh555
Yes, that’s right.
Message 8 of 12
chlrjsgh555
When I enter the SNAP command, only the DRAFT SETTING window appears.
Message 9 of 12
chlrjsgh555
I can't see it if I type it at the command prompt.
Message 10 of 12
pendean
Community Legend
Community Legend
SNAP is the commandname for all of us.
.SNAP (with the period in front of it) will call the core command, which will look like what you want: type that at the commandline to see for yourself.
Message 11 of 12
h_s_walker
I know what the OP is getting at. Every time I type SNAP (with or without the period at the beginning) at the command line. I get the image below, this is all input via the command line.
Howard Walker
Left Handed and Proud
Message 12 of 12
chlrjsgh555
Thank you so much
