I have both AutoCAD LT 2021 and AutoCAD LT 2022 open and running side by side. In 2021 I have a normal cursor response. In 2022 it is significantly slower. So slow it is impossible to actually use the software. Also, did the command line get locked and un-dock able all of a sudden?
Solved by krkec. Go to Solution.
Solved by bohodges. Go to Solution.
I'm having the exact same issue: LT2021 seems to work fine while LT2022 has a distinct delay in the cursor response.
So far I haven't found a fix yet.
I haven't noticed any 'slowness' but I do default to 2021 normally. As for your commandline check the 'lockui' variable according to the help file it defaults as '0' (that's a zero) but I did find in 2022 that my lockui was set to 15 which locks everything down so it might have changed default, although it could well have been me that did it for some reason and forget about it. It is a registry setting so changing it is global. Or there is an icon in the lower right of your program window (if it is enabled) that toggles lockui on/off.
The computer is completely up to date, including all updates from Autodesk, Windows and the Nvidia drivers.
Hi guys, i am having the same slow cursor issues, any updates on this one?
I was having the exact same problem. I tried updating my Nvidia driver to the most current version but no go.
Turning Hardware acceleration fixed it for me. Enter "GRAPHICSCONFIG" at the command line. When the Graphics Performance dialog box appears, select "Off" next to "Hardware acceleration" and then click "Ok" at the bottom.
Hope this helps.
@Justin.Doughty wrote:GFXDX12 set it to 0
Thank you for that! I was having the same issue as well, but people in the forums of my native language could only recommend turning off the hardware acceleration as well. Your solution works just as well, without having to give up on the enhanced graphics of the acceleration. Cheers!
We just upgraded to AutoCAD Map 3D 2022 and were having the same problem - this fixed it! Thank you!
I did the same, but when you have to move more complex object (hatch ecc) then you face complete system slow down, jumpy cursor, screen flickering. Simillar as you run out of memmory. So no complete solution.
@krkec wrote:
... but when you have to move more complex object (hatch ecc) then you face complete system slow down, jumpy cursor, screen flickering...
Looks like your system is choking under AutoCAD. Are you using AutoCAD 2022? If yes...
Have you installed the 2022.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
Also read this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/2011-H...
HTH
