Setting an imported image as a background layer?
Message 1 of 8
Good morning everyone. I'm working with imported image to do quick sketches off of but I'm running into a bit of trouble. I'm able to import the image and get it scaled correctly even if the process is a bit cumbersome, but when I go to draw anything it hides behind the image and I have to turn the image off in order to see what I've drawn. I tried changing the draw order, and the layer but that didn't seem to do anything.
Replies (7)
Message 2 of 8
So somehow I was able to get it to work the way I want, but I don't know how to repeat the process...
Message 3 of 8
cadffm
Draworderctl checked?
Whipthread checked?
Try to turn on/off HA,
command 3dconfig
Sebastian
Message 4 of 8
sthompson1021
One thing you can try is to select the image and in properties set the transparency to 50.
Message 5 of 8
pendean
Community Legend
Community Legend
Did you try REGENALL command to fix the draworder setting?
Message 6 of 8
Thanks for writing, is draworderctl and whipthread in a properties window somewhere? When I type these out as commands I get "<3>" for draworderctl, and whipthread doesn't even show up as an available command.
I didn't even touch the hardware acceleration settings when I somehow got it to work how I wanted so I think I will leave that setting alone.
Message 7 of 8
cadffm
Whipthread is ok.
"so I think I will leave that setting alone."
And I think I will leave you and your problem alone.
REGENMODE checked? If available
Do you draw in Modelspace or Layout?
Layout: Check "Plot Paperspace last"
Sebastian
Message 8 of 8
Thanks for the responses everyone, I worked with changing the draw order a bit more and that seems to be what I needed. Looks like some I just needed to take an extra step to get the desired outcome.
